What is Pro Search?
Pro Search is Perplexity’s advanced search feature, designed to deliver nuanced, thorough answers to complex questions within seconds. Pro Search devises the answer by synthesizing information from a diverse and high-quality set of sources. This goes far beyond standard keyword-based searches, functioning more like a knowledgeable search assistant than a traditional search engine.
How do I use Pro Search?
Pro Search is no longer a separate toggle, so there’s nothing to turn on. Select Search and ask your question. Perplexity uses Pro Search automatically when it’s included in your plan, up to your plan’s limit.
Web and Comet: Select Search in the box where you type your question. To use a specific model, open the model menu and choose one, or leave it on Best. For a longer, report-style answer, open the Search menu and choose Deep Research.
iOS and Android: In the Perplexity app, Search also uses Pro Search automatically. To get a longer report, switch the mode to deep research.
The step-by-step process
Model selection: Before starting a search (session) Pro users can choose from several state-of-the-art AI models—including OpenAI’s GPT-6.2 Sol, Claude Sonnet 5.5, and Gemini 4 Hydrogen—each optimized for different types of queries.
Web crawling: The system then conducts multiple searches across the web, drawing from articles, academic papers, forums, videos, and more, depending on your selected focus (e.g., Web, Academic, Finance, Files).
Synthesis and summarization: The AI reads, analyzes, and compiles insights from dozens of sources and summarizes the information into a coherent, well-organized answer. You see not just the summary, but also how the AI broke down your question and approached the research.
Citation and transparency: Every answer includes direct links to the original sources, allowing you to verify facts or explore further.
Interactive refinement: You can continue the conversation with follow-up questions; Pro Search maintains context from previous interactions, enabling a natural, flowing dialogue.
Benefits of Pro Search
Solves complex problems: Pro Search excels at breaking down ambiguous or multifaceted questions, providing detailed, actionable answers.
Saves time: By compiling and summarizing the best insights from many sources, it eliminates the need to sift through pages of search results.
Trustworthy: With full source citations, you can always check the origin of any information provided.
Adaptable: Works for technical, academic, creative, and everyday questions—adjusting its approach based on your needs and the nature of your query.
Interprets code: Pro Search includes a code interpreter that allows you to execute code and obtain fast results. This feature is particularly useful for data analysis, debugging, and content generation, making it the perfect tool for developers and data scientists.
Advanced capabilities
Reasoning models: For advanced analysis on any topic, you can switch to the latest reasoning models like Anthropic’s Claude Sonnet 5.5 with Thinking turned on.
Code interpretation: Pro Search includes a code interpreter for executing and analyzing code snippets, making it useful for developers and data scientists.
Search modes: You can narrow your search to specific content types (e.g., Academic, Finance, your own files), ensuring answers are drawn from the most relevant sources for your needs.
Personalization: The feature adapts to your preferences and refines answers based on your feedback during the conversation.
What are some use cases for Pro Search?
Academic research
Pro Search can function as a research assistant for students and academics. It digs through academic papers and databases, runs simulations, and performs data analysis to tailor its findings, providing summarized papers and curated sources. It’s the smartest way to research.
Professional research
Pro Search can pinpoint cases for attorneys, summarize trend analysis for marketers, and debug code for developers—and that’s just the start.
Code interpretation
Pro Search is a powerful tool for developers and programmers. It can debug code, run simulations, and provide detailed explanations for complex programming concepts. Whether you’re tackling a tricky bug or optimizing your code, Pro Search has you covered.
Validating information
Remember, while Pro Search aims to elevate your quest for knowledge, it’s crucial to validate information by referencing the sources linked in your answer.
Pro Search vs. standard search
Feature | Standard search | Pro Search |
Speed | Fast, basic answers | Slower, in-depth answers |
Depth | Surface-level, 1–2 sources | Comprehensive, dozens of sources, Source databases |
Model options | Limited | Multiple advanced models to choose from |
Source transparency | Basic citations | Extensive, direct source links |
Special features | None | Code interpreter, Create files and apps access |
Standard search is best for quick facts; Pro Search is ideal for research, analysis, and complex queries where depth, accuracy, and source transparency matter most.
